I noticed a drop on the garage floor again and crawled under. Its definitely oil and its not coming from my pan. It looks like its dropping down onto the top of my front diff on the passenger side, and then dripping down the side of the diff and splattering underneath a little.
I looked in from over and under with a flashlight and I can't really see where it would be coming from. It seems like a running leak, which is probably not so good. I wiped everything clean and then checked in the morning and it was still dry, but after a drive there is some oil there again.
The VX is running fine and I am not throwing and codes, so it just seems like a slight leak from somewhere.
Any ideas? I will post pics later.
