Results 1 to 12 of 12
Thread: Misfire/Oil In Spark Plug Well
Threaded View
  1. #11
    May 2003
    Lightbulb
    It wouldn't hurt to make sure your PCV is still "rattling" to indicate it is probably functioning okay. If it doesn't rattle when you remove it and shake it, that could cause crankcase pressure to build and oil will probably leak from where ever the pressure can escape. I only throw this out because I had a "brand spank'in new PCV" fail on me after I installed it for the trip to Moab . Started spraying oil out of my breather cap (aftermarket) and I sucked down a 1/2 quart of oil rather quickly before discovering the problem. (Normally she doesn't use hardly any oil in 3,000mile change intervals.)
    The downside is that even if crankcase pressure caused a leaking gasket; the damage has been done to the gasket or seal and it will probably need replaced even if you restore the pressure to its proper level (functioning PCV).
  1. Spark Plug Wires 8mm
    By isss in forum VX Modifications...
    Last Post: 05/13/2017, 05:54 AM
  2. spark plug problem (not the VX)
    By etlsport in forum Chit-Chat ...
    Last Post: 06/05/2011, 07:39 PM
  3. Spark Plug Install
    By Mile High VX in forum General Tips...
    Last Post: 04/13/2010, 09:05 PM
  4. Oil in spark plug well
    By ojmagg in forum VX Troubleshooting...
    Last Post: 04/24/2008, 12:47 PM
  5. Spark Plug Torques?
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 03/25/2005, 09:49 AM
