Results 1 to 15 of 19
Thread: Check engine
    May 2008
    unfortunately I live in NH and we have annual state inspections.
    if the CEL is on it means that the ECU is throwing a code and the vehicle wont pass inspection as a result.
    lucky me the CEL came on the day before I had my appointment
    I had it checked at a local autoparts place: P0405 the EGR valve position sensor has low voltage... There's a guide on planetisuzoo on how to fix it for a trooper... you can get new and used replacement valves on ebay for about $50-$120 shipped...
    the shop wanted $200 for the part plus $120 for 2 hours labor
    that's an expensive CEL.
    I've ordered an OBDII reader so I can scan my own codes (and reset them)... not to mention they're handy to have. and I'll try the DIY fix... failing that I'll buy a used one no way I'm paying over $300 for some emissions garbage that's killing my mileage anyway.
    Quote Originally Posted by twistedsymphony View Post
    the EGR actually helps your mileage.. at least if its clogged up.. try cleaning it first and making sure that the wires are properly connected to it
    May 2008
    yeah I'll definitely try cleaning it first.
    I would think that an EGR would hurt you mileage since it's routing the exhaust fumes (which is theoretically devoid of oxygen) back to your intake... wouldn't the reduction in burnable air cause a less complete burn?
    i meant to say... replacing your egr will help improve gas mileage.. when it get clogged up gas mileage suffers.. i dunno if you would gain anything by removing it all together
    Maybe, but also contains un-burned fuel...
    1997 Silver JDM 0623
    Hi ABS sensor faults are generally caused by a build up of brake dust over the sensor or the exciter rings - either a jet wash or remove the disc and clean them up works just fine - mine was coming on every so often - but since i cleaned the exciter rings and sensor face it hasn't come on once and the TOD seems to work better
    cheers
    Steve
    2001, Ebony Black, 1153
    That is what I thought, but all they seem to ever check every single time is the emissions. I live in Houston and we have very strict inspections, and I used to always have troubles getting the VX inspected until I took that bulb out. I do not think they check for fault codes unless there is a light.
  1. Check Engine Light
    Last Post: 11/05/2007, 08:11 AM
  2. Check Engine - Off/on/off/on what..
    By Corrosive in forum VX Troubleshooting...
    Last Post: 11/22/2006, 03:12 PM
  3. check engine
    By alobar05 in forum VX Troubleshooting...
    Last Post: 06/28/2005, 08:57 PM
  5. Check Engine
    By Eckstream in forum VX Troubleshooting...
    Last Post: 10/02/2003, 08:22 AM
