Results 1 to 2 of 2
Thread: Bilstein Shock options
    Dec 2004
    I just saw something that caught my eye on the "VX Lift options Wiki" thread but I didn't want to hijack...
    The Bilstein shocks for the VX are listed as:
    Front - B47-1738-H2 (or -H1 for more stiffness)
    Rear - B46-1739-H1
    I installed these on my VX (H1's in front) a couple years back, and while they are an excellent choice for the VX with a very close-to-stock ride, the rears are probably stiffer than they need to be, and a softer one might be appropriate for the VX. After all, these Bilstein models are actually the ones they recommend for the Trooper (they don't have a recommendation for the VX), and the longer Trooper probably carries more weight on the rear axle, requiring a stiffer shock to counteract the additional inertia.
    So - my question is this...
    Does anyone know if Bilstein makes a B46-1739-H2 shock for the rear?
    2000, Kaiser, 0134
    A quick search of Bilstein's site turned up a "no" answer. Their site is really really good for searching. Too bad they don't have a vx specific shock setup.
    I was just about to order the bilsteins but I don't want to make the Rear shocks stiffer. Might have to do some research on other options for the rear.
    BTW I hope you don't mind but I added your quote to the Lift wiki thread.
  1. Bilstein 5125 Shock Absorbers?
    By TheGanzman in forum VX Modifications...
    Last Post: 05/12/2015, 03:02 PM
  2. Shock Replacement - Bilstein direct replacement?
    By Feidhlim in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/11/2009, 06:17 AM
  3. Bilstein fitment problem
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 06/27/2006, 01:03 PM
  4. Bilstein Shocks Info
    Last Post: 10/13/2004, 02:42 PM
  5. Rancho 9000 vs. Bilstein 5150 ?
    Last Post: 06/22/2004, 12:13 PM
