Yes, that is correct. I want to say my ABS light came on about a year ago, was kinda on and off for several months, and now it is constantly on. But personally, I like the feel of the brakes with the ABS off, especially when wheeling. On the ice and snow with a steep downgrade in Reno is another story. I have slid a lot in the snow here and I have to be very careful when driving in the winter here. I have had 2 very scary slides where the VX just didn't want to stop on the downhill. I don't think the ABS had anything to do with it though. Reno does not plow in the winter, and with the drastic temp changes from day to night, we can have it raining in the day, which quickly turns into a nice sheet of ice as soon as the sun goes down, and then it snows on top of that creating wonderful driving conditions.
My ABS light came on AFTER I replaced my brakes and rotors for the first time. I don't know if that had anything to do with it, but who knows.
Did you ever do any diagnostics on the ABS module to determine why the light came on?
mine came on after the stainless steel lines went on.. but a good long time after. it seemed to be affected by temperature.. the colder it was the more the abs worked.. until one day it just stopped working all together.. i have the module.. but no real motivation to install it since i have never had a close call due to lack of abs
I lost my VX's abs when I fitted a new set of drilled and slotted rotors which I bought from the US, can't remember the supplier's name though.
It wasn't the rotors fault but the pads they supplied with the rotors and my mechanic who chose to ignore my instructions to fit a pair at a time and fitted all 4 at once.
Everybody had their own thoughts as to why the brakes had gone 'soft' and no abs, they were so bad as to be dangerous as no matter how hard I stood on the pedal it would take far too long to stop, but I suggested fitting 1 pair of the old pads to a front brake to see and suddenly the brakes started to come back!
After fitting the old front pads and a set of new rear standard pads everything was fine again and still is 2 years later.
The supplier, whose name I shall post when I find it, denied this could happen suggesting that we had done something wrong but wanted me to return the new pads to the manufacturer in the US as it was his problem not theirs!
As I'm in the UK shipping costs and no guarantee of a refund prohibited this.
Anyone else experienced 'bad' pads?
I never have in 30+ years of car dealing, racing included.
Clive, I think is a common problem aftermarket brake suppliers should be aware of. My symptoms were the same with the R1 Concepts brake pads. Simply put, stopping power was gone, resulting in MANY scary situations were my VX did not want to stop. All those problems are gone now with stock pads. Kenny said he found out that it was the thickness of the aftermarket pads.
Clive,
It sounds like you've solved your problem, but not too long ago I replace all four rotors (SP Performance drilled and slotted), all four sets of brake pads (OEM's), and installed the stainless lines. The brake system drained itself dry (due to my stupidity of not plugging the open hard lines) and I had a bear of a time getting them bled. I finally caved and brought it to a local mechanic who did some research and found out that in order to bleed our brakes properly the engine has to be running during the process.
We got a lot of the air out of the lines, and the VX stops on a dime now, but once stopped if I push on the pedel hard it will go all the way to the floor. I think I just need to bleed the brakes again to make sure all of the air is out of the lines. I spoke with Tone and he said that he went through a LOT of fluid when he did the same thing. So to all I would say; bleed the brakes a few more time to see if that helps stopping power.
The pad thickness was fine it must've been the material-too hard or 'cold'.
Re brake bleeding and pedal travel we've found that the pedal can be made harder and shorter by adjusting the rear calipers. A couple of my VXs had horrible feeling long pedals and this cured the problem.
Thanks for your replies, Clive.
I'm not sure exactly what my mechanic did to my brakes but when I had him replace the rear pads (oem) and rotors (aftermarket, flat vented).. afterwards my brake pedal barely even makes it to the level of the gas pedal, its nice, tight, predictable, even perfect braking!![]()
I can honestly say that I've never heard of the thickness of pads causing ABS issues...
Brakes are really f-ing simple... you have a big cylinder attacked to the pedal then a bunch of hoses that connect that cylinder to a whole bunch of little cylinders which clamp the pads to the discs.
abs is pretty much completely separate, there are sensors in the drive line that monitor wheel speed, that gets fed to a computer module and when it detects that a wheel has "locked up" based on it's speed then it controls a valve in the brake line to pulse the brakes on and off...
I can't possibly imagine a scenario where changing the rotor (or any other part of the brake system) would set off the ABS light. Theoretically you could completely remove all of your calipers and the BMC too and the ABS would be honkey-dorey as long as the sensors and computer module were ok.
thinner pads could make the brakes squishy... but they would have to be REALLY thin... are these R1 concepts rotors thinner than OEM as well? because that would help.
Upgrading to a larger Brake Master Cylinder (or just adjusting the factory BMC if it's possible) would probably solve the squishy brake issue... or just rebuilding the calipers, or upgrading to better fluid... lots of things and improve brake pedal response. In my experience the pads and rotors have little to do with the firmness of the pedal unless they're both REALLY bad to the point where you're exhausting the capacity of the BMC.
I did replace the stock rotors for the R1 concept rotors,then i bought a canadian-brand ceramics pads,the result hasn't be so desappointed.
After a while i had the squeezing noise,but that happen because i hard to brake had when a couple of eldery were driving and seemed to be lost at that moment,they made a full stop in the middle of no where at 55 mph,my brakes were installed about 60 miles ago and as we know the brake pads needs to adjust it's self for the 1st 1000 miles.
However the squeeze noise is only heard once in the morning when i pull out the garage.
Dakar was just the begining.
OK, real stupid question but I have to ask it. When anyone with an ABS light issue has replaced their rotors, did you move the ABS sensor ring from the old rotor to the new one? Even after switching out everything (rotors, pads, and lines) on my VX I have not had a problem with the ABS light coming on.
Just a thought.
My brake/abs problem didn't bring the warning light on but due to the 'cheap' pads no matter how much brake pressure I applied the abs wouldn't work on the road as the pads weren't gripping the rotors enough. If I tried it on gravel/loose surface or cobbles/shiney surface the abs worked fine. Fitting standard pads brought everything including the pedal pressure back to normal. (My mechanic did originally leave the rear, I think, abs sensor rings off which did bring the light on & confuse us even more for a while though!).
Thanks to 'twistedsymphony' for the tutorial on braking systems but new cheap 'bad pads' can cause pedal pressure problems.
Clive
