Results 1 to 6 of 6
Thread: Stock Brake Pad Replacement
    2000, Ebony, VX, 0370
    Thanked: 12
    For those of you who have replaced your brake pads with stock Isuzu/ pads; what are the little packets of goop that come with the pads for? There is a packet of orange goop and a packet of black goop. I am guessing that the orange goop is to lubricate the shafts of the brake calipers so they slide back and forth easier, but I can't figure out what the black goop is for. Anyone know?
    1999, Ebony Black, 1856
    Anti-squeel for the pads and shims?
    Thanked: 12
    That's kind of what I figured, but where exactly does it go? Between the shims? Between the shims and the back of the pad? Between the shims and where they contact the caliper? All of the above?
    Seems like there's enough to coat everything if you needed to.
    Any info. I ordered new OEM pads and don't know exactly where to use the orange and black goop. Any help appreciated.
    Thanks,
    Dave
    Jul 2004
    2000, Kaiser Silver, 0196
    Quote Originally Posted by SlowPro48 View Post
    Thanks for the tip. That's just what I needed.
    Dave
  1. Stock tires on wider than stock rims?
    By Y33TREKker in forum Wheels and Tires
    Last Post: 07/20/2013, 12:33 AM
  2. EBC brake pads and Apex brake lines
    Last Post: 12/14/2011, 02:15 PM
  3. Shock Replacement - Bilstein direct replacement?
    By Feidhlim in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/11/2009, 06:17 AM
  4. possible replacement for stock seats?
    Last Post: 07/04/2006, 10:23 AM
  5. Replacement tires on 18" stock rims
    By Ebony1433 in forum VX Troubleshooting...
    Last Post: 10/21/2003, 01:07 PM
