Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Tone's Moab Videos
  1. #16
    Apr 2003
    ummm... have you tried running the update within Quicktime?
    I always check for updates.. and 'select all'
    MAY help.
    If not.. I'm not sure what else to try.
  2. #17
    Trash what you have and try downloading it again - you could have a corrupted download. Then open it with another video viewing program - open the program and direct it to the downloaded file. I’m trying to finish the DVD of those movies this coming week.
    If someone would like to download and then host them out streaming for those with slow connections or computer issues, I don’t have a problem with that.
  3. #18
    Apr 2003
    Just checking..
    Spazz... you ARE in fact 'right click' ing the videos and saving it locally before trying to watch it, right?
    Also, are you set up as 'administrator' on your windows installation?
  4. #19
    01 White VX #356
    If you have installed the latest version of Quicktime, then I'm going to go with Tone on this one and say it sounds like corrupted downloads.
    Grab all the rars. They'll let you know if they are corrupted when you start to unpack them.
    Although it's really bizarre that all of the downloads would be corrupted.
    Don't tell anyone I suggested this and if you do, I'll deny it, but you could try just clicking (instead of right clicking and saving) on the links to see if quicktime will try to play them. Quicktime do the whole play it as it downloads it thing. If it doesn't want to open them, then it is a problem with your Quicktime install. If it does, then you have bad downloads.
    I forgot where I was going with this post several times, so if it doesn't make sense, forgive me. I'll edit it in the morning for clarity. I'm tired.
  5. #20
    01 White VX #356
    Re: How can I watch these movies?????
    Originally posted by SPAZZ
    um......let me think....am I stupid?....no, I am not stupid.....yes, I am right clicking and saving the movies.....in fact, I have tried everything from deleting(uninstalling) quick time, installing every frigging free download that quick time offers...... ...annoying......and every frigging time I try to watch the movies after downloading to my compute...it says not recognized program of Quicktime...or any other program for that fact
    Do your filesizes match what was posted on the webpage? Downloading huge files like this can be a problem unless you have a very stable connection. I've had my browser just cut off half way through the file and act like it was done.
    I'd recomend downloading something like ReGet (www.reget.com) and having it download it for you. It downloads it in little chunks and if there is a problem with the connection while you are in the middle of a download, it will start up as soon as it can connect again.
    Download Accellerator Plus(DAP) is another option, but I prefer ReGet.
    The way these programs work also tends to speed up download times.
  6. #21
    Apr 2003
    Spazz, please dont take that the wrong way... I have no clue what you tried or didnt try.
    I am starting to think that there is something wrong with your windows installation.
    I am at a total loss on ideas.
  7. #22
    Apr 2003
    Last ditch effort
    2 more things to try:
    First, make sure you have XP Service pak 1 (and any other critical updates) downloaded from http://www.windowsupdate.com
    Then... go to http://security.kolla.de and download the free 'SpyBot Search and Destroy' adware&scumware cleaner.
    After you install it, run it, go to the 'online' tab, select any updates available and install them.
    Then... go to 'settings' and select the 'settings' sub menu.
    Scroll down the list and find the check box under 'web update' and select 'Display also available beta versions'
    Go back to 'online' and scan for updates again. Install them if any are found.
    Next click on 'check for problems' on the lower left.
    Let this scan your whole system. When completed, delete all items that are listed in RED.
    Optionally you can run the 'immunization' tool afterwards.
    I have had some success with misbehaving systems (where they couldnt even open an Excel file!) by using this program in the past. It may not fix your Quicktime problem. But it certainly wont hurt.
  8. #23
    Originally posted by TimG
    A camera mounted on the roof would be awesome. I enjoyed the cockpit views that you provided, but noticed that you would turn off/put the camera down right before you did anything really extreme. A good driver could have done it while looking through the camera.
    I had a camera mounted on my sunroof years ago when I ran a rally in my Amigo. It was a ton of fun and I was able to watch it over and over again. Of course, I remember my girlfriend at the time couldnt sit in the same room when I watched it cause she hated the fact that i did such "dangerous and fanatical" sports, heh.
    I even have a cool little 20 minute movie of a trail run with a camera mounted over my headlight on my 4 wheeler. That was really cool looking too, until the end of the flick when I nose dived off a drop off about 12 feet, heh. That, my friends, was the end of that camera.... and the nose bar.... and the headlight.... and the left front sway arm.... and the.... *sigh*
    2001 Proton VX #0662
    Re: How can I watch these movies????? no luck, tried that/.........same issue
    Well I don't know if it would be worth it just to watch the videos, but it would definitely pay off many times the cost in reduced aggravation over several years if you get an Apple (Mac) computer. I fight with my Win-doze computer more in the first hour at work every day than I have with my Macs in the 7 years I've used them. Until you've given BillGate$ the one fingered salute and come over to the good side you can't imagine that computers can be a daily JOY to use instead of a constant struggle. No one every regrets 'switching' and being rid of M$ after all the grief. Good luck anyway and know I feel your pain!
    Back on the subject of the movies.... Those are FANTASTIC Tone (finally figured out from watching them that your name rhymes with 'phony', not 'phone'). They are REALLY great if you watch all four of them at the same time so there is always some serious action happening! Some of those shots you got are unreal!
    Canadian VXer!
  10. #25
    01 White VX #356
    I've been thinking about getting one of the new G5's. Those things are nice. I'd still have to keep a windows box around for gaming & work related tasks (I'm a programmer), but I could change my main machine over to OSX with no problems.
    The first time I met him, the first question i asked was phone or phony, and he said it was up to the individual. I chose to call him Mr. Monday since he wouldn't give me a straight answer (I didn't know him well enough to just call him anthony).
    After hanging out with him at a few meets I've found that people use both phony & phone, and it's probably pretty even on the percentages. Jay calls him Tone (phony) every time. George calls him Tone (phone) every time. I tend to use the last thing I heard someone call him.
    Truthfully, I don't think he really cares which one you use. He answers to Tone (phone), Tone (phony), and Mr. Monday. Next time I see him I'll see if he also answers to Anthony.
  11. #26
    May 2002
    2000, Proton Yellow, VX, 0584
    He sometimes answers to "Hey you!" also.
    Scott / moncha.com
  12. #27
    01 White VX #356
    I forgot about that. Yes he does.
    On thread related note. I changed the server to https only (because of some other stuff I have running on there), so if you bookmarked anything it will stop working unless you change the bookmark to https instead of http. I fixed my original post to point to the right place.
  1. New toy = new videos!
    Last Post: 01/16/2012, 08:11 AM
  2. decided to post some videos
    By Hybrid1098 in forum VX Talk...
    Last Post: 11/09/2011, 08:07 AM
  3. 2009 Tone/MOAB Memorial t-shirt
    By LittleBeast in forum VX Talk...
    Last Post: 05/20/2009, 09:56 AM
  4. Moab 2008 Videos - Tuesday VX Only Run
    Last Post: 12/09/2008, 04:52 PM
  5. VIDEOS: Elephant Hill VX Run - Moab, UT 2007
    Last Post: 12/09/2007, 04:47 PM
