Yes.. I researched it on Isuzu.com and 99's hat a 6/60.. oops!
well hopefully its that mode thingy the others are talking about.. I will back out and watch.. good luck!
Jeff
Jeff
Part # is 8960175110. isuzuparts.com calls it a neutral safety switch and lists it for $158.82 + shipping
Merlin: http://isuzu.stcharlesauto.com/Department-Parts.aspx
(Zorak) Thanks You![]()
(Zorak) If not the neutral safety switch problem ....what do you thing ??? any scanner can find the problem? what do u can suggest![]()
You might try doing a search under "transmission slipping" or something similar and see whether anyone else here had similar problems with their tranny that turned out not to be the mode selector swtich. I don't think this will throw a code so not sure a scanner would reveal anything, but I could be wrong.
The other apparent indicator of a mode selector switch fault is that when you get the clunk, the gear indicator light on the instrument panel does not indicate the correct gear: either it is out altogether or shows a gear other than the one you are in. If you notice this happening then the mode selector switch is probably the culprit
Good luck. Anyone else want to chime in here, feel free.
you covered it pretty well zorak.. if you had it into a shop already i assume they checked the fluid level.. but it cant hurt to check it again, a few members have had slipping caused by low fluid level
my first guess would be the mode selector switch, the flickering/incorrect gear indicator on the gauges is another symptom of it going bad, but it does not always happen so even if you dont have that symptom, still start with the selector switch
(etlsport) Thanks of the advice
(Zorak) Thanks ...I already installed neutral safety switch and I take the road test (stop the car and accelerating I feel the first gear (only) slips (hesitates)) but not the all time. What do u thing I need to do... change the transmission filter or change transmission fluid . If I want to check the transmission fluid and how to tell the fluid level is good.![]()
