Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: need help and advice Transmission rebuild
  1. #16
    Dec 2004
    DLNTHO - After changing the tansmission fluid, did you run the shifter through all the gears before your final top-off of the fluid?
    I remember reading here several times that if you refill the transmission fluid you need to cycle it through the gears and then add some more fluid, otherwise you won't add enough. If you didn't do this, then maybe you don't have enough fluid in there.
    Good luck!
  2. #17
    Oct 2003
    1999 white
    (VehiGAZ) Thanks I will add some more fluid
  3. #18
    Arrow
    Quote Originally Posted by DLNTHO View Post
    Here it is again............................................. ......
    Hope it clears up some of the mystery for you.
  4. #19
    2001, Dragon Green, 1342
    Not saying it's your problem, but it might of lead to it:
    from workshop manual:
    Changing Transmission Fluid
    There is no need to change the transmission fluid unless
    the transmission is used under one or more of the
    following heavy duty conditions.
    A. Repeated short trips
    B. Driving on rough roads
    C. Driving on dusty roads
    D. Towing a trailer
    If the vehicle is used under these conditions, change the
    fluid every 20,000 miles (32,000 km.)
  5. #20
    Oct 2003
    1999 white
    rowhard (Thanks)
    Ldub (Thanks) any best way to pump the Transmission Fluid ,today I went to Autozone and the saleman told add some LUCAS fluid in transmission for slips protection ? I want to know did any one use this fluid before??
    http://www.lucasoil.com
  6. #21
    Oct 2003
    1999 white
    Thanks for everyone help and I have more question ??? now my transmission had slipping and what do u guy thing is the transmission harness wire fail???solenoid or ASM cable also is have any kind of the scanner can scan and point out the transmission problem.
  7. #22
    Apr 2010
    2001 VEHICROSS WHITE 1297
    Transmission Light On
    My Vehicross Star To Have Hard Shift In 2 Gear And The Transmission Light Turns On... But When I Tunr Off The Car The Light Turns Off And The Car Shift Ok, But The Like 10 Minutes Later Is The Same The Light Turns On And I Have The Hard Shift..... Maybe I Have Overheating Transmission Problem, What You Gays Tink....
  8. #23
    Apr 2010
    Transmission Light On And Harshift
  9. #24
    01, LineX tan/black, 1055
    Quote Originally Posted by MMOROLEON View Post
    Ummm, I am not one of the gays, but I would say you need to do tranny maintenance, and perhaps not capitalize every word. Sounds like your tranny fluid may be low, or filter is bad. If you have it serviced, print out the refill procedure from the VX maintenance tech manual and make them follow it. Otherwise, a few thousand miles later you will start having sliupping and whatnot.
  1. Replies: 61
    Last Post: 03/02/2016, 10:31 AM
  2. Transmission went out:( Replace or Rebuild??
    Last Post: 01/07/2014, 10:51 AM
  3. transmission problem or need rebuild
    By DLNTHO in forum VX Troubleshooting...
    Last Post: 08/05/2009, 03:44 PM
  4. manual transmission advice (not in VX)
    Last Post: 02/10/2007, 08:50 PM
  5. Transmission rebuild?
    Last Post: 02/01/2004, 09:10 AM
