Results 1 to 5 of 5
Thread: 6.5 inch rear speaker installation (photos)
    Mar 2008
    99 Ebony #1989
    OK, last night I stayed up late getting this done, and it actually went together without any issues. If you are installing rear speakers, and are iffy about where to cut the brackets, and are installing Infinity 6022si's (shallow mount) these pictures should help you. If you cut where I did, there shouldn't be any issues.
    Also, I re-used the old nuts from the cutouts as I thought they would hold better than the ones that shipped with the speakers (I like to keep things stock ). All in all, it wasn't nearly as hard as I thought it was going to be.
    Enjoy! PICS BELOW!
    http://picasaweb.google.com/joel.theo
    cool! very well done! mine didnt look nearly that clean
    Apr 2006
    2000 dragon green 0496
    How did you get such a clean cut when you modified the speaker bracket.
    What did you use to cut the bracket?
    Mar 2008
    99 Ebony #1989
    You can see in one of the photo's that I used a small cutoff wheel. It allowed me to control the wheel and make a circular motion to etch the metal. I did that a few times, and made the etch deeper each time, finally cutting through the metal.
    The large grinder is so powerful and heavy, I found myself cutting more off than I wanted, which is why I used the small cutoff wheel.
    In the end, it does not matter that much since you will never see the bracket
    I just wanted to make it look perty
    Sep 2007
    very nice job, mine also did not come out that well.
  1. Need Rear Speaker Writeup
    By ipd in forum VX Modifications...
    Last Post: 08/31/2016, 01:07 PM
  2. Rear Speaker Sizes
    By alanbradley in forum VX Talk...
    Last Post: 09/22/2009, 07:24 AM
  3. Rear speaker replacement
    By Chopper in forum VX Modifications...
    Last Post: 10/31/2007, 07:17 PM
  4. Rear Speaker Cover
    By Mark B in forum VX Talk...
    Last Post: 09/01/2006, 06:40 PM
  5. Rear speaker access
    By crager34 in forum VX Modifications...
    Last Post: 02/21/2005, 02:19 PM
