Originally Posted by
LittleBeast
Ok please tell me that this is not normal, this photo is from under the VX looking at the area just to the passenger side of the oil pan, I believe that is the flywheel, clear as day exposed to the elements, this is not normal right? I think the Aamco guys forgot to put the dust cover back on right? Am I crazy?
I just crawled under my VX and there definitely is a dust cover over that area. I tried to take a picture, but it was just too tight to see through the view finder. Got a nice picture of the cross member though.
LittleBeast
What do you think about this loose tube located just above the exhaust pipe directly behind the trans? Does it need to attach to something? I have attached a photo of the tip and where it attachs to something, any ideas? Did the Aamco guys just forget to attach this? Would this be a reason my cruise control is now not responding at all?
There is only one rubber line in that area on mine, and it is connected to the tranny, as pictures in the second shot. Not sure what the other one is.
LittleBeast
Ah and here once again is the little trans fluid cooling line that has sprung a leak for the 3rd time, how awesome. Could this be because Amaco is not flushing the lines after working on the trans and it is clogging up causing pressure to break this part time and time again?
Maybe they need to replace that rubber line. If it's split or cracked the hose clamp won't contain the pressure.
Gregg
2001 Proton Yellow #1379
