Results 1 to 8 of 8
Thread: Oil in spark plug well
    1999, Ebony Black, 1856
    I changed my spark plugs this evening, I noticed some oil in a few of the sparkplug wells...I noticed the engine misfiring a bit on a test run to my buddies house...do I just need to change the well gaskets under the valve covers, or is there more to this job? Should I take it to my mechanic to be safe?
    2001, Dragon Green, 1342
    So was the oil sitting on top of the valve covers, on top of the spark plug boots, 'on the right hand bank?? maybe some one before you was sloppy when pouring some oil in it
    I wish...the oil was below the threads...
    my friend, I wish it had been that easy. I wish you had been a computer nerd and didn't know the difference between a spark plug and a gas cap. Maybe you are on the verge of serious problems, maybe it will be a simple fix, either way, I will stay tuned just in case I ever have this problem. Good luck mate
    I am a computer nerd...system admin..!
    Well, since the VX was running smooth before I changed the plugs...I'm hoping that this condition was caused by too much anti-size compound on the spark plug threads (it doesn't start to misfire untill the engine get hot)...I'll clean it up this weekend and let you know..
    Just throwin' it out there as a possibility(on the misfire issue)...maybe a cracked insulator on one of the plugs???
    My guess would drivers side/rear.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    If i was you i would take it to a mech, trust me, it's worth it.
    Turning My VX Into Rally VX
  1. Spark Plug Wires 8mm
    By isss in forum VX Modifications...
    Last Post: 05/13/2017, 05:54 AM
  2. spark plug problem (not the VX)
    By etlsport in forum Chit-Chat ...
    Last Post: 06/05/2011, 07:39 PM
  3. Spark Plug Install
    By Mile High VX in forum General Tips...
    Last Post: 04/13/2010, 09:05 PM
  4. Misfire/Oil In Spark Plug Well
    By 100kVX in forum VX Troubleshooting...
    Last Post: 06/03/2008, 06:18 PM
  5. Spark Plug Torques?
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 03/25/2005, 09:49 AM
