Results 1 to 15 of 19
Thread: HELP Ball joint flip problems VX on blocks!!!!!
    Feb 2005
    01 Kaiser Silver
    I am assuming you are referring to the Swordy's sway bar disconnects (long red round connectors with pins holding them in place)? Or maybe the greasbale sway bar bushings (short red bushings going around swaybar with gold metal connectors)? Well the sway bar disconnects are for gaining a little more suspension travel while off roading. The greasable sway bar bushings make the VX go from the loudest rattling SUV ever heard to a quiet running LittleBeast!!!!! But don't worry, the LittleBeast is about to be a BigBeast.....
    Its the disconnects. Mine arent as thick. WAAAY smaller. Cool thanks that is what i was talking about
    Thank you for the reminder I need to greese everything that i put on mine.
    2001, Ebony Black, 1153
    Red face
    Quote Originally Posted by Dumke View Post
    Yeah I know, I just bought a grease gun and everyday as I do more to the VX I find more things under there to grease (and clean up). I have become a greasing fool!
  1. Ball Joint Flip - Did you do it? Why? Why Not?
    Last Post: 02/05/2016, 09:07 PM
  2. diff drop/ball joint flip
    By raver_boi_88 in forum VX Talk...
    Last Post: 06/19/2013, 10:36 AM
  3. Any advise on glue for window fix + ball joint flip help
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 04/16/2010, 07:57 AM
  4. Ball Joint Flip Problem
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 06/09/2008, 08:35 AM
  5. Purpose for ball-joint flip?
    By coachreed in forum VX Modifications...
    Last Post: 09/15/2003, 05:37 AM
