My trailer light adapter quit working. It ended up that the ground point I chose was bad.
High tech solution: I pinched the ground wire between the jack and the retainer bracket. It worked like a charm but since I'm Anal Retentive (AR), I'll eventually fix it right with a solid ground point![]()
