Results 1 to 15 of 15
Thread: couple of vx questions
    hi guys.
    does anyone know what is the max speed you can engage TOD? like can i put it on when im doing 30kph ? 100 kph? (55mph)
    er..had another question but ive forgotten it!!
    oh yeah! where do you attach a rear 4x4 tow hook? i cant see anywhere underneath to put one.. like the one on the front...
    Mar 2006
    2000 White Ironman 0160
    TOD is always engaged unless you have a 2wd and 4wd switch.
    you will have to install a rear hook or a reese hitch. There are a couple of different designs, do a forum search..
    2001 Proton VX #0662
    Maybe you're asking what's the max speed you can drive in with 4WD engaged.... that's one I've always wondered. I've taken the Detroit freeways at about 50mph sometimes and it sounds like my VX is going to blow up even though it's at about 4000 rpm I think. All the gears are just screaming. I know it sounds like you wouldn't want to go that fast if the road was slippery enough to have to use 4WD but here it's the choice between going 15mph in the slow lanes or 50mph in the GrandCherokee lane sometimes. It'd be the perfect time to have a switch that would lock it into 4WD-high.
    Canadian VXer!
    ok... sorry.. i have a lever.. 2wd... tod... and 4wd lo....its a japanese vx.. so i have a manual lever for putting it into TOD or 4WD lo... normal driving is rear 2wd
    what i want to know... is can i put it into TOD while the car is in motion.. if so.. at what speed is the limit?
    Interesting.... in the US we only have two choices on the lever! It's either TOD or 4WD-lo. You're owners manual must say what the limit is. Let us know!
    yes.. my owners manual.... all i need now is a japanese speaking hot female to translate it for me.....
    Dec 2004
    HAH!! LOL!! :-)
    Castigan, our US VX's are different in that we have only 4-Hi and 4-Lo to shift between. Our manual is quite strict and explicit - only shift while completely stopped and with transmission in neutral.
    yes. ive noticed i can apply TOD while moving... and ive never done this except at very low speeds... i was just wondering what would be the maximum speed it could be engaged at... intresting that yours are always in TOD.... bet i get better gas milage with rear 2wd only engaged !!
    Dec 2004
    I bet you do, too. Pardon my JDM model ignorance, but do you have the 3.2L motor or the 3.5L?
    yes we have 3.2l engine.....
    Dec 2004
    That probably helps your mileage too.
    Apr 2007
    2001, Proton #1238
    The TOD has no speed limit. I was reading about the development of the TOD system. It was designed to be used at any speed. I also found out that Ford uses the same system under a different name. I lot of time went in to the development of the TOD, it truly is an engineering masterpiece.
    Aug 2007
    2001, Proton, VX 1394
    jdm transfer case...
    would a jdm 3.2l VX's transfer case bolt up to our 3.5l? and if so would we have o do electronic werk or could we just pll the brains out of a jdm?
    that would be cool!
    it reminds me of my 4runner, i could engage 4wd at speeds ur to 35mph i believe
    Apr 2007
    2001, Proton #1238
    As far as I know they are the same. It’s just the electronics that’s different.
    id be inclined to think it would just be a transfer box.... maybe computer also.. not sure really...... could be a big job... hehe.. i know nothing..
  1. Couple of random questions
    Last Post: 05/04/2015, 09:28 AM
  2. I have a couple questions.
    By RodL in forum VX Troubleshooting...
    Last Post: 03/18/2013, 07:02 AM
  3. Just bought 01 VX! Couple of Questions...
    By stinger101 in forum VX Troubleshooting...
    Last Post: 01/06/2005, 05:39 PM
  4. Couple quick questions
    By Lease-V-cross in forum VX Talk...
    Last Post: 05/03/2004, 02:30 PM
  5. My new VX!!! (and a couple of questions)
    By VXRaNgEr in forum VX Talk...
    Last Post: 01/19/2004, 02:23 PM
