Results 1 to 8 of 8
Thread: Engine Knock Vs. Timing Belt Tensioner
    Feb 2004
    '01 Ebony #0830
    http://www.vehicross.info/forums/sho...t=10722&page=3
    A HUGE THANK YOU TO COWBOYERIK!!!!!!!!!!
    I've been in a VX depression ever since I heard that darned knocking sound in the motor. I even warned my wife about the "potential" of the motor going kaput long ago. After reading CowboyErik's post, I felt I had hope still. Sure enough! I pulled off the passenger side timing belt cover enough to push on the belt. Without any trouble at all I was able to deflect it by almost an INCH! So, after about 45 minutes I had the front end torn apart and found that the timing belt tensioner went bad!!! I can plunge the piston with my hands with ease, and there is oil leakage around the "pushrod" base. (see pics).
    SO, IF YOU THINK YOU HAVE ROD KNOCK/ENGINE FAILURE, CHECK THIS BEFORE SENTENCING YOUR VX MOTOR TO DEATH!!!!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    This is good info., I've heard of this on the 3.2(mostly sohc?, not sure), but this is the first I've seen of it on the 3.5.
    Thanks to Cowboy Eric & Silver Bullet 75.
    Sep 2010
    2000,Ebony,VEC,0013
    WOW! So this could be my number 1 cylinder Knock! I have been bracing myself for several months now for the engine to DIE.
    Feb 2004
    '01 Ebony #0830
    If you take the timing belt covers off, you should be able to deflect the timing belt pretty easily by hand. If this is the issue, you just saved $k's!
    Dec 2010
    2000,Red,Trooper, 1234
    Quote Originally Posted by Ebenezr View Post
    Ebenezr ... I have a knock that appears to be on number 1 cylinder too.
    Did you check your Tensioner? If so, what did you find?
    Thanks
    Carl
    Oct 2003
    1995 Isuzu Trooper LS
    On the 3.2Ls, a diagnostic for the timing belt tensioner is if the knock goes away at higher rpm, above 2000-2500 rpm. But it can definitely sound like a death rattle, when my tensioner went out at Moab, everybody who heard the motor looked like they were at a funeral. But instead it was a $65 part.
    Sep 2010
    2000,Ebony,VEC,0013
    I can't get to it. Prying the cover back I can't do. When I put a stethascope on it the tap is loudest coming from the timing cover top bolt which enters right into the no. 1 area in the head. It will have to be torn apart to check but for the engine runs great. I am going to rev the engine today like BigSwede said and see if it disappears.
    Dec 2010
    My engine tapping goes away above 2500 rpms too and the engine runs great.
    I need to open the timing covers and take a look see too.
    Carl
  1. Replies: 4
    Last Post: 01/31/2013, 03:04 PM
  2. Best timing belt,water pump,tensioner etc...kit to get
    By bigblock8396375 in forum VX Talk...
    Last Post: 04/07/2011, 12:26 PM
  3. Timing belt replacement and timing videos
    By deermagnet in forum General Tips...
    Last Post: 11/26/2007, 09:09 PM
  4. Serpentine Belt Tensioner removal
    By Maugan_VX in forum VX Troubleshooting...
    Last Post: 08/22/2007, 07:23 AM
  5. Belt tensioner
    By scarpezio in forum VX Troubleshooting...
    Last Post: 02/07/2007, 02:22 PM
