Can 22" wheels fit on a stock 99 Vehicross?
just wondering....found a good deal.....
What's the width and offset on them? Could give you way more details if you give the specs. OEMs are +38 offset, I just put -2 offset rims on…required lots of trimming, so, do 22" fit?…it depends…how much cutting/trimming are you willing to do...
22's are awesome if you are running 40's or bigger
OR....
this was in '08
Test fit one before you pay. Some members have had to modify rims after purchase in order to clear the hub. 22's will clear the caliper though which would be the main interference point.
If you buy them, make sure you're using the right lug nuts for that rim ... there's no guarantee that the OEM ones are the right ones for those rims.
ROFL
I thought that his comment meant that running 22" rims was like totally like so yesterday!
