That's what I have on if you want to see it in person. It's (very)easy to install, it's the bleeding that takes the time. I also used this:Also, I am considering this kit:
http://www.independent4x.com/item.jh...0&PRID=1221569
Is anyone running the above brake line upgrade? Opinions? If I order this, I will probably have a brake shop install.
http://store.summitracing.com/partde...5&autoview=sku
and this:
http://www.rotorsandpads.com/AteSupe...SUPERBLUE.aspx
I agree with etlsport on the system being a bit leaky, but once you tighten down all the lines and get that infernal right rear clip seated right it's fine.
