lately ive noticed my audio system has been "clipping" very lightly, ive adjusted my input levels on the amp (everything from the head unit is RCA to the amp, 4 surround and 2 sub channels) to cure the problem and its ok for a while then it will start to clip sometimes and then stop again randomly.. all on the same drive, but theres no alternator whine at all
im wondering if the RCA voltage isnt consistent because my monitor will occasionally cut out for 5-10 seconds every 30 minutes and just say "no signal" (i have a head unit that plays cds/dvds and a separate monitor connected via yellow RCA)
whats the best way to check the voltage? can i just disconnect the RCA from the amp and bridge the gap with an ohm meter? or any other ideas about what could be causing it
