Results 1 to 7 of 7
Thread: Help!!! My Check Engine Light Is On!!!
    Oct 2006
    2001 PROTON VX #0756
    Hi. I went to Auto Zone and they ran it on their scanner. The codes are P0171 and P0303. Could someone tell me what they mean? What needs to be changed out? Your help is greatly appreciated. Thanks, Nancy
    p0171 is "system too lean (bank 1)" from what ive read it looks lilke its usually caused by a bad intake manifold gasket.. which is common on our engines
    p0303 is a cylinder 3 misfire, could be spark plug, maybe intake manifold gasket? not sure someone else can chime in on this stuff
    2001, Proton Yellow, #0580
    They both could be caused by the bad gasket. The original spec had the torque value too high - over time the phenolic fails. I don't remember the new value - something like 9 lbs (original was double that). It's not an expensive fix if that's what it is, provided you can do it yourself (part's aren't too bad).
    -- John
    i think the new value is 13ft-lbs and the original was like 17-19
    Can't recall the codes but my check engine light came on recently and one of the values pertained to the engine running lean. I also noted that it would stall out easily at low RPMs. Turned out to be a missing screw from the EGR that resulted in a vacuum leak. Replaced screw and Check Engine light went out as did the stalling problem.
    Scott
    Oct 2006
    Manifold Gasket???
    If I have to replace the intake manifold gasket, am I better off getting it from Isuzu or AutoZone or Napa? Or are they all the same? Spec torque? Thanks again, Nancy
    Quote Originally Posted by littlewing2 View Post
    Whenever replacing a part that you have to "dig" for, meaning removal of all sorts of other stuff, before you actually get to the part in question, such as timing belt, water pump, thermostat, intake gaskets, etc., I usually choose OEM Isuzu.
    There was just a post a bit ago, lamenting the fact that the brand new autozone water pump that had just been installed leaked from day one.
    For speedy service, good prices & free shipping, search Merlin @ St Charles Isuzu.
    jU$T MY $.02
  1. first check engine light
    Last Post: 04/26/2010, 07:36 AM
  2. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  3. Check Engine Light
    Last Post: 10/29/2007, 01:25 PM
  4. Check Engine Light...
    By dobie3 in forum VX Troubleshooting...
    Last Post: 12/11/2003, 02:45 PM
  5. Check engine light just came on...
    By Inaba in forum VX Troubleshooting...
    Last Post: 06/28/2003, 10:52 AM
