View Poll Results: Do you want a turbo kit for your VX?
Voters
128. You may not vote on this poll
  • Hell yeah!!!
    97 75.78%
  • Nah, i'll stick with stock power
    26 20.31%
  • Whats a turbo?
    5 3.91%
Page 6 of 8 FirstFirst ... 2 3 4 5 6 7 8 LastLast
Results 76 to 90 of 106
Thread: GI: Turbo Kit
  1. #76
    Is that similar to the Vortec superchargers for the 350Z and G35? Idea is that it goes beside the engine rather than on top right?
    And what constitutes being a "volunteer?"
  2. #77
    Apr 2006
    2k Ebony
    Yeah similar set up. Get the goods and I'll fab brackets and piping. Its easy.
  3. #78
    Oct 2006
    01 Green Dragon 00291
    Quote Originally Posted by jdm monkey View Post
    yeah first coolant was getting into the spark plug hole.
    How does the coolant get into the spark plug hole?
  4. #79
    Apr 2006
    2k Ebony
    I suspect cracked head. I replaced both heads.
  5. #80
    Sep 2010
    1999, Silver, 0447
    jdm how much would it cost to set a vx up with the supercharger kit your talking about?
  6. #81
    Apr 2006
    2k Ebony
    There's no fixed price yet but it should go for around $3.5K
    Update:
    Done with the piggy back fuel controller for the VX!!! I'm trying to make a plug and play solution right now with no ECU wire splicing.
  7. #82
    Sep 2010
    1999, Silver, 0447
    3.5k isnt bad... im liking the sound of that lol
  8. #83
    Oct 2005
    2001 Proton Vehicross
    Sooo if i come visit ya for a weekend can we get it done : D
  9. #84
    Apr 2006
    2k Ebony
    Quote Originally Posted by Lizardmen3477 View Post
    yeah we'll get it done....
  10. #85
    Mar 2010
    1997, Green, JDM, 1196
    SuperCharger kit for 3.2 / 3.5 Ltr GM Engine
    Well, I was poking around on the web (nah, I don't crawl.... haha) and gues what I found in the North-Western Island called "Australia"?
    You guessed it - A SUPERCHARGER KIT
    (see below)
    The quoted power (185kW / = 250Hp) is based on the lesser 6VD1 from the Trooper, factory rated at 142kW = 190Hp)
    That's a 60Hp increase, meaning that your 6VE1 would max out at about 270-ish HP or 200kW for us metricans.
    Damn - that's close to the max rating for the auto-trans!
    CHECK about the re-tuning of the PCM/ECU to suit the Pressure vs. Vacuum and the extra injector
    Worth checking out...
    http://www.capa.com.au/kits_holden_rodeo.htm
    "Holden 3.2L-3.5L V6 Rodeo Eaton Kit
    Retail Price: $6,995.00
    Rated Horsepower of Kit: 185kW
    Parts Included:
    All parts are included, except exhaust
    Eaton Supercharger
    Cast Aluminium Inlet Manifold
    Supercharger driven by factory belt system
    Intake Pipework, inc. Throttle Body Adaptor
    7th Injector with Aftermarket Management
    Comments:
    This kit is ideal for standard engines."
  11. #86
    Oct 2012
    2001, Proton, 0586
    Looks like JDM Monkey hasn't been on since Feb. I wonder if he is still playing with his VX. Since I am thinking about doing my own mid mounted turbo kit, I would LOVE to hear some of his details.
    AEM FIC piggy-back engine management appears to be powerful enough to give us everything we need!
    Some comments about lag, were the original CATs still used on this system? If so, they could have been a MAJOR contributor of this lag! You really shouldn’t have CATs before the turbo! Now, it isn't 100% legal to move it after the turbo ether, but lets face it, most of us will not have to deal with CARB .
    While you could get away without an intercooler (under 10 psi), it can still help you! With intercooler, you will be able to ether run lower octane gas and/or run more aggressive timing. So I wouldn't dismiss it "just because you can".
    I think that engine management is THE most important part of well executed turbo/supercharger system. I think I will start by installing AEM FIC, wideband O2 sensor and larger injectors, BEFORE I actually install a turbocharger. Learn how to tune it and only then install the turbo, which is actually the easy part of this job .
  13. #88
    Nov 2012
    1999, White Ironman Ed., 1707
    I wish I didn't live in Cali sometimes it really bites!!
  14. #89
    Apr 2006
    2k Ebony
    Sorry guys I've been busy at the shop. Another option would be a Rotrex supercharger set up. It is easy to install and very compact. We have successfully fabricated a kit for a Lexus GS400 and can be easily adapted into the VX. I anticipate the kit for the VX to be around $5800.
    Here are some pics to get an idea how the setup looks like:
    http://youtu.be/FI71dswjRSs
    http://youtu.be/R4k4msBP9Uw
  15. #90
    Nov 2005
    FYI - several VXs in Russia are using Rotrex S/C already.... at least one of them switched from Alpine and claims that Rotrex gives a much bigger boost..
    Vodka... Connecting people
  1. Turbo Setup For Our Car? What ya Think About This One.
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 11/24/2010, 05:29 PM
  2. STS Turbo kit...
    By killinformula in forum VX Talk...
    Last Post: 02/09/2009, 05:31 PM
  3. more prep for the turbo
    By morgan-tec in forum VX Modifications...
    Last Post: 05/22/2005, 11:40 AM
  4. turbo kit
    By MrCrowley in forum VX Talk...
    Last Post: 10/15/2004, 10:51 AM
  5. turbo?
    By zuzuAmigA in forum VX Talk...
    Last Post: 04/02/2003, 06:06 AM
