So let's revisit my last trans thread:
http://www.vehicross.info/forums/showthread.php?t=12112
and the terrible update: AAMCO "fixed" a leak in a coolant hose the same day I picked up the VX, and low and behold, right now the SAME HOSE THEY JUST "FIXED" has another leak!!!!! They just "fixed" this same hose two months ago right after they just completely rebuilt the transmission and the guys I had do the oil change pointed it out to me. Now, it is 3 quarts LOW on trans fluid and is shaking going into 1st. This was a low tranny fluid problem and was caused because they did not fix this problem last time when I asked them to!!!!!! So guess what????? They are right now dropping the transmission again and repairing the internal parts that are damaged that are causing this shaking. This should be totally covered by my warranty..... It better be I am about to my limit of nice guy treatment.....
