OK guys, just today, my VX started flashing the 'CHECK' light under the TOD. Following the above instructions, it looks like you need to jumper pin 4 or 5 with pin 8 on the diag connector. I did this with a paperclip, and it does not change the flashing. Am I doing something wrong? It just keeps constantly flashing, it does not flash....flash flash for 12 or anything.
Any suggestions? I am going to try some copper wire when I get home, maybe the paperclip isn't conducting enough. The paperclip works in my Trooper's diag terminal so I can't see why it wouldn't work here.
Anyway, the VX is running and shifting fine, I'm hoping its just a sensor or something.
Thanks - Bart
