Well as the title says the low beam on the passenger side is out, fuses are good and so is the filiment in the bulb. I replaced the bulb just to see. Well I then thought a ground maybe, but the high and low are grounded at the same point with the same wire( I believe). I then checked the plug and everything looks fine. Anyone had this problem?
Thanks in advance for any help
-Zak
