Jason, do those parts still work? Do you know which color you used for Driver and which for Passenger sides?
Thanks
Thanks
I only installed the drivers door clip. It still works fine. Don't recall the color but only one or two in the package are close. Just give them a try.
Jason White
2001 FoxFire Red VehiCross
That Advance Auto, part number 75450 did the trick. I had two clips that were broken. One was up at the top near the outside handle, the other at the very bottom. In the process of getting the one on at the bottom, I broke the upper clip of the lower rod. I ended up using two sizes overall and had to get a second package. If any fail, I predict it to be the top one near the handle because it just didnt seem to click into place quite as well as the others. Time will tell.
While I was in the door, I decided to investigate the problem with the window ha binding going up. I had always assumed I broke the plastic support at the bottom of the window. But it was fine. Now I just have to figure out how to fix the binding.
01 VX/ 09 Cube/ 87 Supra /73 Vega/ 67 Ranchero/ 56 Lincoln
Recently got mine from St. Charles Isuzu and if I remember correctly, Drivers is Black, and Passanger is White.
I called St. Charles Isuzu a few weeks ago and they only had the passenger side in stock. They said that there were no more available for the drivers side in the US and that they might be able to get one from Japan but they seemed think it was possible not to be able to get them anymore.
Not sure, but sounds like you're NOT familiar with the various fixes for this VERY common problem.
Here's a post that lists many of the "fixes" for the window binding.
Most of us have been able to fix them 100% w/o buying any replacement Isuzu parts.
http://www.vehicross.info/forums/sho...55&postcount=5
Thought I was in trouble when my drivers side handle stopped working, but a quick post on here and got the answer to what was wrong.
Last month I order the driver and passenger side clips from http://isuzuparts.com/partscat.html and got both...about a buck a piece.
