That Advance Auto, part number 75450 did the trick. I had two clips that were broken. One was up at the top near the outside handle, the other at the very bottom. In the process of getting the one on at the bottom, I broke the upper clip of the lower rod. I ended up using two sizes overall and had to get a second package. If any fail, I predict it to be the top one near the handle because it just didnt seem to click into place quite as well as the others. Time will tell.
While I was in the door, I decided to investigate the problem with the window ha binding going up. I had always assumed I broke the plastic support at the bottom of the window. But it was fine. Now I just have to figure out how to fix the binding.
