Hi, I seem to have the same problem as a lot of people here, the heater resistor u/s.(fan on full) I have removed the offending item but it doesnt appear to be the same as described on this site.
It is 6 sided,it is held in by 2 screws, but it only has a 3 connecting pin plug like so: __
I I
the 6 sided plastic cover ( the bit you can see before you remove it) lifts off of a finned aluminium heatsink about 1 1/2" square revealing a 1 1/2" square circuit board which is soldered via 3 joints into the heatsink area...which I cant get into.(without unsoldering those joints)
My vericross is a jap model 97-anybody any ideas?![]()
