Results 1 to 7 of 7
Thread: Idle control valve
    2000 Proton Yellow VX 0586
    Idle control valve
    Does anyone know where the idle control valve is? I'm having problems with my rpm's over revving and I was told to try cleaning the valve but I don't know where it is. Thanks
    2001 Proton VX #0690
    It is a little can-shaped thing pretty much front-and-center of the engine bay. It sticks out of the left side of the throttle body. Go find the tech manuals (available on this site!) for pics. Keep in mind that it is also called the IAC or Idle Air Control valve.
    2001 Proton VX 0790
    Get a new gasket before you remove it. On mine it was just a cracked gasket causing the problem.
    John C.
    Jun 2007
    2001, Proton
    what tool is needed
    I was going to chenge mine the part seems to be held on by two bolts. The heads seem to be allan wrench fittings is this correct? Does anyone know what size?
    That sounds correct. I don't recall which size, but it isn't anything out of the ordinary.
    they are Torx screws... size is T20
    Jun 2007
    2001, Proton
    Thanks
    I couldnt find my allen wrenches (accumulated one at a time by buying u assemble furniture) This weekend I thought that they holes did not look like allen wrenches when I got a better vantage.
  1. Fast idle, low idle, (stalling) temp gauge all over the place.
    By Nikad92397 in forum VX Troubleshooting...
    Last Post: 11/07/2016, 08:48 PM
  2. After market vs. OEM Idle Air Control Valve
    By JWJohns in forum VX Troubleshooting...
    Last Post: 03/07/2014, 07:42 AM
  3. Odd Idle Control Problem
    By WebbRacing.com in forum VX Troubleshooting...
    Last Post: 06/17/2011, 01:29 PM
  4. where is PCV valve located, and how do i clean the valve tube?
    By CoastieCosta567 in forum General Tips...
    Last Post: 05/14/2007, 09:33 AM
  5. Egr Valve
    By coolk41 in forum VX Troubleshooting...
    Last Post: 10/10/2005, 06:09 AM
