So this morning I thought since I finally got some time off when it is semi nice outside I would finally install my lenses.
Got out there, took some pics for before shots and got them unwrapped, First I install the passenger side since that so happened to be the side I unwrapped first. Not impressed with the fit at all on the corners I decide to do the front turn signal and be glad to take off the one that I got from Ron. It fit pretty well and seals with the gasket.
Now I do the drivers side corner and I still am NOT impressed with the fit. Next, I go to the front signal and noticed that the lens has an ‘R’ marked on it. I thought man this better still fit. Naturally it does not. So now I have an email in to them and see what we need to do to fix the situation.
So I am not impressed with the fit on the corners because the hole is not in the right place. If you read Bart’s post then you know kinda where I am going. There is play on the front part, which I don’t like at all. I am worried about how long until they break with all the freeway driving that takes place around here.
I will see how she responds with the email to decide if I want to drill the hole to make them fit right or send them back.
