Results 1 to 3 of 3
Thread: Trany light
    Mar 2006
    2000 White Ironman 0160
    Trany light
    While driving home lastnight my trany light came on and and stayed on. I was about five minutes from home. Had been driving for over an hour. It stopped upshifting from 2nd to third and fourth. I will check the fliud when the weather warms up on monday. I checked the manual to try an trouble shoot it. Said maybe solenoid A. Has this happened to anyone before?
    i would limp it to a shop to get the code read... could also try resetting the computer (disconnect battery for 30 minutes) and see if maybe it was just a one time thing and your computer put the transmission into limp mode to save the tranny from further damage
    Mar 2006
    I will try that tomorrow. I will drive it over to Advanced Auto tomorrow night.
    I checked some of the trouble shooting tips from the guide and this is a problem my trany has Test:
    Check 3rd gear in “D” in winter mode.
    Does vehicle move?
    if yes :Shift solenoid A
    stuck. Replace
    shift solenoid A.
    if no: goto step 4
    Check for suspected conditions modifying delays to clutch apply:
    — 2nd clutch seal damaged.
    — Excessive 2nd clutch piston travel.
    — Defective accumulator piston.
    — Causes of internal leaks.
    — Check ball missing or out of location in 2nd clutch.
    — Seals cut, damaged or missing.
    — Gaskets defective.
    — Causes of burned clutch plates.
    solution repair or replace
    Thanks for the suggestion
    do you think it is cheaper to buy a reman or have this one repaired. I also have 96 isuzu rodeo for a possible donor but it has the same mileage as the VXaround 130,000 +/- i believe it is the same 4L30-E trany.
  1. Rear cargo light + underhood light
    Last Post: 05/29/2010, 09:00 AM
  2. trany flush woes
    By Francesco Rizzo in forum VX Troubleshooting...
    Last Post: 01/30/2008, 05:40 PM
  3. Changing trany fluid every 6 month?
    By djkymar in forum VX Talk...
    Last Post: 10/15/2007, 07:27 PM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 09:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
