Just a quick question please...yes, it is Christmas and I am in the garage working on the V....putting on some soft Rancho 5000 for the wife....
Had little problem with the rears but the driver front...removed the lower shock bolt and still could not get the shock bolt out....is this bolt just a slide out after removal of its nut????....or does it actually thread in?????....or is it just plain frozen to the lower barrel of the OEM shock?????
Before I go apply the heat to it I fhought I would at least ask the question....
I would like to have a dollar for every shock I have replaced that the barrel was frozen to the bolt.....
Thanks in advance and hope all had a merry christmas.....
). Lift your VX overhead, use your longest 20mm wrench and a 3 foot piece of iron pipe to extend the handle to put more leverage on it. From a standing position that item will come off with minimal effort with the proper leverage. Hope that helps.
