Results 1 to 7 of 7
Thread: RPMs are over revving
    2000 Proton Yellow VX 0586
    Help! I'm having a problem where my rpms are revving too high when I slow down. It's idling at about 2500 and if i put it in to neutral it runs up to 3000 and won't kick down. Makes it a real bear to stop! Wondering if any ideas of what it could be. Thanks
    check out this thread.. good info on checking the idle control valve and other various things that could be causing your problem
    http://www.vehicross.info/forums/sho...ight=high+idle
    Sep 2005
    1999 Astral Silver VX #0351
    Thanks, this is very helpful! I have been having the same problem ocassionally and had read somewhere that it could possibly be due to the manifold intake gasket. But thinking about it now, there is a good chance it is the ICV since the problem is very sporadic, only high RPMs and hasn't gotten worse over the last few months.
    I'm going to see if I can locate the ICV and clean it with carb cleaner.
    1999, Ebony Black, VX ,1976
    Mine did it a couple times and I cleaned the MAF sensor and have not had a problem since. Make sure to use the right cleaner. shawn
    1COOLVX
    Sep 2005
    And the right cleaner is one that is safe for electrical systems? Or is there another specific cleaner that is right for this job?
    '01 Ebony #0939
    Although I've never used any, I believe there are MAF specific spray cleaners available.
    Quote Originally Posted by Dare2Dream View Post
    Yes there is a specific spray for the maf sensor. shawn
  1. revving engine
    Last Post: 10/15/2012, 09:56 PM
  2. Replies: 39
    Last Post: 05/30/2010, 01:55 PM
  3. A/C only gets cold at higher RPMs...
    Last Post: 08/26/2009, 10:34 AM
  4. Off the throttle the rpms drop big time
    By bigdogdeee in forum VX Talk...
    Last Post: 05/04/2005, 01:44 AM
  5. Trans shifting and RPMs?
    By 14erclimber in forum VX Troubleshooting...
    Last Post: 09/26/2003, 11:11 AM
