Results 1 to 9 of 9
Thread: Need Help Desperately.....
    Oct 2003
    2001 Dragon green 0669
    NEED HELP DESPERATELY!!!
    When I parked my VX this am , I turned the lights off along with the engine. It had run fine.
    Came out noon time to find my side marker/parking lights on . Checked the light stalk switch and it was in the off position. BUT...these lights were on anyway!!
    The headlights still worked, the alarm(isuzu when bought) still armed and disarmed ok. Tried to drive and it bucked stalled and all the warning lights on and off...
    SOUNDS LIKE AN ELECTRICAL PROBLEM...BUT is there anyway to home diagnose it. I'm sure the dealer will rape me like usual....if I bring it there.
    ITS STUCK IN A PARKING LOT!
    I'm in NNJ...anyone know a mechanic who can handle this and doesnt charge an arm and a leg?
    Any help would be greatly appreciated!
    "MARS ATV"
    NASA's Martian Surface Exploration All Terrain Vehicle Prototype
    Jun 2005
    2001 Black VX
    Isnt there a sensor in the shifter that can stick sometimes? So if you put it in drive and then put it back in park (with the engine off), it might fix it?
    I dont know where I got that info from, and could be wrong- but it cant hurt to try...
    2001, Ebony Black, 1153
    I have had my share of electrical problems with the VX there are a few things it could be
    -I had a yellow top battery that had been drained and was powerful enough to do a lot of things (alarm included) but not sustain the VX running.
    -There is a master set of wires that run all the way down to the transmission that sometimes frays and causes all kinds of problems, normally the problem is around the area directly behind the drivers side headlight. You will see a thick black bunch of wires, be careful and look for anything unusual.
    -This same bunch of wires goes all the way down to where the trans shifter lever plugs into the TOD and such. Could be a problem there.
    -I had this entire set of wires replaced and it did not fix my transmission problem, but it has cleared up some other peoples electrical problems. Try searching you might find something else.
    -Ryan
    2001 Proton VX 0790
    For now, I would pull the fuse for the lights, jump it and get it home.
    Check the relays, one might be stuck.
    John C.
    Oct 2003
    Stupid question but how do you check the relays?
    I will check the wire harness as suggested also
    thanks for the suggestions....I have to abandon my VX in the parking lot at work but can fiddle with it Sat am...
    Any more suggestions would be appreciated
    Thanks to all
    Dec 2002
    2001 Ebony 0177
    I'd almost bet on harness problems. Look for any worn spots in the areas mentioned, it won't take much....look carefully.
    where are you? I'm in northern new jersey until monday morn, possible I might be able to find you if you're close enough I can help checking the relays and use my vx to see if anything else looks/acts abnormal to help further diagnose
    Sep 2004
    1999, Astral Silver, VX, 0938
    I think I remember a past post of a simular prob and the trouble area was wiring under the pass, seat that rubbed and grounded out..Good Luck..
    Aug 2007
    99, Silver,0140
    I had the same problem or something close. I pulled the alarm fuse and then reinserted it and it hasn't happened again.
  1. Desperately Seeking V-Cross in Central Georgia
    By DuggerVX in forum VX Talk...
    Last Post: 01/03/2003, 09:44 AM
