/bump
Can anyone tell me why I'm getting the clunk downshifting into first after the tranny is warmed up? How to fix it?
/bump
Maybe you have some valuable input on this Tone....
I actually noticed something that has been happening more frequently lately. I have had the Interceptor installed since about 3k miles. I now have about 13k. When I drop the pedal for heavy acceleration, dropping from 3rd to 2nd, it kicks into second, but slips for a split second then pops back into 2nd. Almost like it hits 2nd, hesitates, and then decides to go. I have not changed out the transmission fluid since new and thought maybe I would give that a go to see how it works out.
Any idea what this slip may be coming from?
Try turning the pressure down Inaba and WormGod - also fluid may need replacing.
Inaba, I found that cutting back the pressure node will take care of most of the hard shift/clunk. It seems to depend on driving style of the said driver. I believe I have mine set between 35-40 now. Works out well for me. I get a hard shift/clunk every now and then, but that's usually in heavy traffic when I am going between 2nd to first. The Interceptor may not be very traffic friendly.
I would just toy with the pressure until you find a suitable setting.
What might help, is to adjust either the pressure or the shift delay...not both. That way you can more efficiently track down which one to adjust.
It�s not the delay...
My pressure is already barely at 20% I'd say...
What exactly does the pressure do for me, anyway? I'll try turning it down a bit more, though.
