I read the write up in the how to section, but did
see an answer to my question.
Which is, other then the trans feeling like its working fine
and has enough, is there a clear cut way of knowing its at
the correct level ?
For example, do you want to fill it thru the fill hole till it wants
to seep out the same hole ? and then thats technically "full" ?
Thats sort of what Ive gathered so far, thanks.
