Thanks for this board. It has a ton of info and helpful info. Thanks.
I am stuck in a horrible deal due to the fact that the dealer I bought the vehicross from was using 2.5" wheel spacers and 17" GMC wheels on the VX. The offset is perfect but the wheels wont clear the 108mm hubs the VX has hence the spacers. I am looking at a set of eagle alloys with the following specs
Rim Size 17x8 Bolt 6x5.5
Offset: -4 mm Backspace: 4.25 inch
Will these tuck into the wheel wells better? I am lifted with OME 912's and a tb crank. With my current wheels I can only run a 245/65/17 without rubbing issues. This is the same as stock size. I want to run a Nitto Terra 265/70/ 17.
Any help would be awesome thanks
