Results 1 to 10 of 10
Thread: need a help again with another problem.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    i'm not sure, but when it stalls its fast and all i have to do is pull over and start it up again, or it almost stalls and i press the gas to kick the idle back up.
    Turning My VX Into Rally VX
    2001,FOX FIRE RED MICA,0251
    Maybe the fuel pump is going out,they can sometime work and not work before they die.
    If you haven't changed the fuel filter already, that would be an inexpensive & easy place to start. It may or may not be the problem, but if it hasn't been replaced, it's probably due.
    Apr 2003
    1999 Astral Silver 1222
    Clean your battery terminals and posts with a wire brush too. Same as above. If it hasnt been done, and you live in a salty area as well, just peace of mind. Had a similar issue in a different vehicle. Just hope its that easy!!!
    Jan 2007
    i did a super clean up on the terminals and with a new battery a week ago and the fuel filter change as well. but still not good new. So do u guys think its the fuel pump and/or the mode switch?
    1999, Ebony Black, VX ,1976
    Quote Originally Posted by CoastieCosta567 View Post
    It sounds more like an electrical issue to me.There was a problem with wiring harness wearing through and causing problems.Do a search and you should find something or someone that remembers will chime in. The fact that it stalls when hitting a hard bump would have nothing to do with the fuel pump or filter or the switch. The mode switch caused hard shifts not stalling. When it stalls does everything shut off or just the motor? Could also be a loose connection . Check all + / - connections at the motor. Check the plugs to the computer. Hope this helps. shawn
    1COOLVX
    Aug 2006
    99, Silver, 1773
    I tend to agree with the Loose connector or bad ground type of problem, but if that isn't it, there are other less likely possibilities:
    Too many keys on your key chain? Sometimes people hang lots of keys and things on their key chain and it messes up the ignition switch. When they hit a big bump it would move things around in there.
    Probably not it, Just an idea to try.
    Also, an old battery could have problems when bounced hard enough (again, not likely, but something to think about). Maybe the battery is shorting to the hood if it's too tall or the hood padding is missing???
    My 2 cents worth
  1. HID problem
    Last Post: 07/29/2010, 05:28 AM
  2. Driving problem fixed/TOD problem realized
  3. Possible TOD problem
    By BritVX in forum VX Troubleshooting...
    Last Post: 02/17/2010, 01:21 PM
  4. Got a problem
    Last Post: 09/21/2006, 04:32 PM
  5. AC Problem
    By wwstone in forum VX Troubleshooting...
    Last Post: 07/22/2006, 06:37 AM
