Results 1 to 9 of 9
Thread: To Supercharge or Turbo my Ironman
    Aug 2007
    1999,white,Ironman5678
    Looking for information about weather to put a supercharger or turbocharge my Ironman?
    id say if you can find a supercharger(they are discontinued) thats the way to go.. they are well documented on the site already and proven to work by many owners... the only turbocharged VX that i know of turned out looking like this....
    Jan 2006
    Or you can customize one of these centrifugal supercharger setups:
    Isuzu Axiom, same motor.
    This was a custom setup by Morgan-Tec. He no longer has it and no longer builds custom parts...
    Dec 2002
    2001 Ebony 0177
    Without a major reconfiguring of the engine layout (reducing compression etc. etc.) you are not gonna get a whole lot from either approach. You are limited to maybe 5lbs. of boost...tops. 20 or 30 hp. at best. Good thing too...the theoretical limits of this tranny is South of 300hp.---the practical limits are much lower. Three grand for twenty horses isn't much of a horsepower bargain in my book. Chopper
    2001, Proton Yellow, #0580
    Hey Wayne,
    It's actually more like 40-50 hp at the rear. Look for the dynos from Cyrk's compared to mine pre-SC. I still need to schedule a run to compare apples to apples (or would it be bananas to bananas on my proton?).
    -- John
    John Eaton
    Original Owner
    2001 Proton Yellow #580
    Atlanta GA
    "Metaphors be with you"
    Dec 2002
    2001 Ebony 0177
    50 on the driveshaft is much better....at least you can "feel'' it. My point was, if you want a street racer, there are much better platforms out there. This is a hard place to start on a hot rod without a total revamp. P.S. I am not simply trying to goad someone into gutting one, and making an eleven second machine out of it, before I do. No truth to that at all
    Apr 2005
    2001,grey,2 door Dunno
    All that space and plumbing could have been avoided if a water to air intercooler was used.
    A water to air intercooler is an intercooler with a water jacket on it and can be placed on the side of or on top of the intake. Then a radiator would be plumbed below or in front of the existing water radiator.
    This has 3 advantages.
    1. There is no need to disfigure the vehicle.
    2. Plumbing distance and elbows are GREATLY reduced optimizing the efficiency of the turbo and you wont get the lag as in the set-up above due to the distance being short for the boost to travel.
    3. The are new liquids that can be used that dissipate heat much more efficiently than ambient air as in the intercooler (air to air) used in the et-up above.
    That was the way we set up the HUMMERS and they where truly, truly beasts….
    Oh, leave it to Chopper....
    T/C isnt very likely to happen without Foose (and some $$) or some other fab master on your side at this point. And a S/C is just about as likely now that the kits have gone for a walk on the mammoth's back.
    Oct 2004
    2001, Yellow (PROTON) VX, Supercharged
    Alpine S/C has been flawless
    My Alpine S/C has been flawless with no problems whatsoever since it's install. Changing the serpentine belt can be somewhat of a problem since you have to dismantle a few things and i'll be getting into that pretty soon. Otherwise, BeeVenom has had a very noticeable change in performance although i don't know exact hp change. I'm figuring probably 40-50hp??? but will dyno it this coming Spring. S/C is the way to go I think.
    Scott
  1. GI: Turbo Kit
    By jdm monkey in forum VX Modifications...
    Last Post: 07/12/2016, 10:32 PM
  2. Turbo Setup For Our Car? What ya Think About This One.
    Last Post: 11/24/2010, 05:29 PM
  3. STS Turbo kit...
    By killinformula in forum VX Talk...
    Last Post: 02/09/2009, 05:31 PM
  4. turbo kit
    By MrCrowley in forum VX Talk...
    Last Post: 10/15/2004, 10:51 AM
  5. turbo?
    By zuzuAmigA in forum VX Talk...
    Last Post: 04/02/2003, 06:06 AM
