So I had an AftMrkt alarm installed last week and spoiled myself with the remote start feature.
Everything works fine, unless it's started using the auto start;
The TOD seems to not activate upon starting (0 out of the 3 front end boxes lit up), until the tranny hits 2nd or 3rd gear, then the TOD activates and 'overreacts', causing a noticable clunk with all 3 boxes lit up.
Again, this does not happen when started normally with the key.
I've searched through threads about remote starters and was aware of this one even before the install:
http://www.vehicross.info/forums/sho...d+remote+start
Taking particular notice to this quote:
The VX is back at the shop as we speak getting looked at for a solution.
But is there any other info out there I should be aware of?
Thanx all,
Cy
Is just not compatible any way.
