4 bt is a 665lbs, ISB (6 cylinders is at 785lbs.
Just FYI...
Joe
Just FYI...
Joe
That weight is basic nearly-stripped, meaning not quite what you need to run. Here is the long block weight from my Cummins shop manual, minus flywheel & accessories (starter, alternator, etc.):
CSB (Cummins Svc. Bulletin) 3666087-01
B3.9 and B5.9 Series Engines
Section E- Engine Identification
Specifications Page E-5
General 4B Engine data
4BT= 705 pounds, 320 Kg
4BTA = 725 pounds, 329 Kg
When you get the flywheel, transmission adapter, mounts, accessories (starter, alternator, etc.) and such on there then you're over 900 lbs. and nearer a half-ton.
Hey Joe, do you or anyone else happen to know the weight of our 3.5's?
The weight of the 6VE1 doesn't appear to be in the CD manual and I unfortunately do not yet have a print shop manual. But in doing some online research and contacting a few rebuilders the best answer is "about 400 lbs." in basic trim.
I'll keep my eyes open for more definitive data.
SCHWEET! Thanks, I'll see what I can turn up too...
