Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 64
Thread: Diesel swap: help needed
  1. #46
    Nov 2002
    Wait, you recommended the 4BD2-TC as a good swapper before, didn't you? That was part of my basis for posting that link; what did you figure out? It's just too heavy for the VX?
    Funnily enough, I was looking for swap ideas for the CUCV and stumbled upon that link, referenced it here, and what do ya know, the only other CUCV/VX owner is the 1st to notice! Do ya think the 4BD2 is a decent candidate for the CUCV? I have a 700R4 that I think will bolt up although it is a 2wd unit so I would have to have a divorced t-case as well. My other choices are a Banks Turbo kit or perhaps a Cummins 4BT... Been leaning toward the Banks but thought I would check out some options. I'll have to change my screen name to IDon'tKnowWhatIWantEither!
    Yeah, it's just too heavy for our torsion bar suspension. Great engine though, although the more I learn about the 4JG2 the more I like it. I mean, it's not like Isuzu makes bad diesels, right? Of course the folks in Oz are getting their flame-typing gloves on to skewer me about the 4JX1!
    A while back I picked up a Silverado minus engine as a cab donor for my M1028 and it came with a freshly built 700R4. It's tempting but I'm going to hold out for Kodiak/Top Kick 5-speed manual, that way I get the best of both worlds. Once I'm done putting a flatbed on my Mack I'm hoping to finally do the cab swap on the M1028 and put it back on the road. Too many projects!
  2. #47
    Jul 2007
    1999,Astral Silver,VX,1349
    hmmmmmmm....ok
    [SIGPIC][/SIGPIC]...
  3. #48
    '01 Proton #0317
    Not relevant to diesel conversion, but my longterm plan is to eventually convert mine to two wheel drive and 100% electric - much like the RAV4's that Toyota built several years ago. The VX - sans rear seat - makes the PERFECT candidate for an electric conversion. Lots of room behind the seats for a battery bank, full frame construction, (already) heavy duty suspension, and ultimately, a good roof platform for solar panels. The battery technology is getting better/cheaper/faster quite quickly. Look for substantial "energy credit(s)" - especially here in California - in the coming years, as we continue efforts to reduce our dependence on foreign oil. It was all part of my "master plan" in actually picking the VX in the first place; I'm looking forward to this project in a few years!:bgwg:
  4. #49
    Nov 2002
    The weight of the VX is the killer in an all-electric application since mass is the enemy of efficiency. My fantasy electric is a VW Vanagon: unibody construction for light-weight strength, plenty of room, phenomenal underbody space for simple full length drop-down battery trays to optimize balance and lower CG, existing transaxle for simple bolt-up motor mounting with existing electric systems (either AC with regen or DC), and best of all you can make a "safari roof" of solar panels the full length of the Vanagon to not only provide supplmenary power and off-grid charge but passive cooling just like on older Land Rovers. You could even get radical and use two motors with a Vanagon Synchro for AWD!
  5. #50
    Quote Originally Posted by Joe_Black View Post
    ... My fantasy electric is a VW Vanagon...
    Wow, that's a pretty sexy fantasy there...
    But hey, get it right and this could be you:
  6. #51
    Sep 2010
    1999,VX, 2477
    Thanked: 8
  7. #52
    Thats a pretty good deal considering it has the tranny, tcase, wire harness, computer and front drive shaft.
  8. #53
    Hard to say it's a good deal if they don't list the mileage...
  9. #54
    True
    Should have said potentially a good deal
  10. #55
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    It's a JDM engine, so I'm making an educated guess that the mileage is ~50k or less. I'm more surprised to see the MT than I am the engine, TBHWY.
  11. #56
    Quote Originally Posted by eBay Ad
    Your Swap comes with :
    Engine
    At transmission
    What you're seeing in the picture is the 4WD shift lever, not the 5-speed lever.
  12. #57
    Nov 2007
    1997 SILVER
    Our experience here in Aussie, is to avoid the 3.1L diesel engine if you can.
    The earlier 2.8L diesel turbo makes the same amount of power if the fuel pump is tweaked, and is far more reliable, uses less fuel, and has less turbo failures.
    PK
  13. #58
    But can it be mated to the AR-5?
  14. #59
    And what do you know about the 4JX1 3.0L diesel? According to Wikipedia it superseded the 4JG2 3.1L in 1998 but was more "problematic."
  15. #60
    Apr 2011
    99 Ebony, VX, #2007
    200 tdi or the 300 tdi wouldn't be to bad but might run you a lil bit more cash.
    they are the 4 cyl diesels out of the range rovers, I have been eye balling them for a while.
    http://www.landroverimport.com/contact.html
    here is a link to a sight that got me interested in the motor but I'm sure they can be found cheaper than that.
  1. fry oil diesel
    By FlyingV77 in forum Chit-Chat ...
    Last Post: 10/27/2014, 07:00 PM
  2. Diesel swap
    By HeckaTrebeka in forum VX Talk...
    Last Post: 09/10/2012, 08:27 AM
  3. Diesel VX, Possible?
    Last Post: 09/10/2012, 08:20 AM
  4. Diesel Swap into 1999 Vehicross
    By sleveritt in forum VX Modifications...
    Last Post: 02/01/2010, 08:30 AM
  5. Replies: 2
    Last Post: 06/23/2008, 07:33 PM
