Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 64
Thread: Diesel swap: help needed
    Quote Originally Posted by eBay Ad
    Your Swap comes with :
    Engine
    At transmission
    What you're seeing in the picture is the 4WD shift lever, not the 5-speed lever.
    Nov 2007
    1997 SILVER
    Our experience here in Aussie, is to avoid the 3.1L diesel engine if you can.
    The earlier 2.8L diesel turbo makes the same amount of power if the fuel pump is tweaked, and is far more reliable, uses less fuel, and has less turbo failures.
    PK
    But can it be mated to the AR-5?
    And what do you know about the 4JX1 3.0L diesel? According to Wikipedia it superseded the 4JG2 3.1L in 1998 but was more "problematic."
    Apr 2011
    99 Ebony, VX, #2007
    200 tdi or the 300 tdi wouldn't be to bad but might run you a lil bit more cash.
    they are the 4 cyl diesels out of the range rovers, I have been eye balling them for a while.
    http://www.landroverimport.com/contact.html
    here is a link to a sight that got me interested in the motor but I'm sure they can be found cheaper than that.
    Apr 2011
    99 Ebony, VX, #2007
    so I got an email back from http://www.landroverimport.com
    a good used 300 tdi with auto trans and transfer radiator, oil cooler, and intercooler would be 4k and a rebuilt would be 6k
    2000, Kaiser, 0134
    When I was dong research I disovered this: http://www.4btswaps.com/forum/showth...4BT-Conversion
    Closest I could find. I also spoke with a local builder who was wrapping up a 4BT in a Land cruiser. The biggest issue with these engines is that they are much taller than even a small block V8. But they're the perfect engine for a VX IMO. Good luck!
    Hello
    I am not owning a VX but i have a Frontera (Rodeo) sport 2.0i petrol..I love the VX but the mpg and taxes in my country are kinda big for > 3000+ engine
    A 2.8L diesel engine should from fronteras should be nice ?.. My mechanic skills are very low...
    Btw i am from Europe..
  1. fry oil diesel
    By FlyingV77 in forum Chit-Chat ...
    Last Post: 10/27/2014, 07:00 PM
  2. Diesel swap
    By HeckaTrebeka in forum VX Talk...
    Last Post: 09/10/2012, 08:27 AM
  3. Diesel VX, Possible?
    Last Post: 09/10/2012, 08:20 AM
  4. Diesel Swap into 1999 Vehicross
    By sleveritt in forum VX Modifications...
    Last Post: 02/01/2010, 08:30 AM
  5. Replies: 2
    Last Post: 06/23/2008, 07:33 PM
