check the fuse for your horn.. sounds crazy.. but when i installed my air horn my scangauge stopped working.. turns out i had my wires crossed and i blew the horn fuse... replacing the fuse made my scangauge work again... turns out the data port is powered through that fuse... fuse is located in the engine bay fuse box
