Results 1 to 11 of 11
Thread: help stalling
    '99
    Adam, this is from the '99 VX repair CD.
    Mark
    When I had a similar problem, the shop replaced my air filter & cleaned the MAS. Problem solved.
    May 2007
    2000, Ebony Black, ....
    I pulled the Idle Air Control Valve on mine, cleaned the crusty gunk off from it, gave it a small shot of PB Blaster, reinstalled it and no idle problems since.
    Thanks for all the help.
    2001 Proton VX #0690
    Quote Originally Posted by Dino View Post
    I pulled the Idle Air Control Valve on mine, cleaned the crusty gunk off from it...
    I did the same thing, and that fixed the problems for almost a year. However, it stalled at a stoplight on me a few weekends ago. I'm told that my EGR is almost clogged, so I'll probably try replacing that, next.
    '99
    Good idea there, Dino. I pulled mine after 160K miles and it was very dirty. It's on the upper left side of the throttle body when facing the engine. The manual says don't immerse the valve in solvent and don't apply so much pressure to the pintle that it moves. Just spray the pintle and spring with carb cleaner and use a tooth brush. Also clean out the area where the valve sits.
    Another easy cleaning job to keep everything running right.
    Mark
    '99 Ebony Black VX, 0339
    Post
    Let's see - he got a MAS code and everyone is telling him to check other things? Aftermarket airfilter? Recently re-oiled? Dirty?
    New MAS is probably around $150 (MBs were $500 I recently found out...) I may have a spare laying around - email me.
    P0101 OBD-II Trouble Code
    Technical Description
    Mass Air Flow (MAF) Circuit Range/Performance Problem
    Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4.0 seconds.
    Possible Solutions
    The simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:
    Inspect for the following conditions:
    An incorrectly routed harness--Inspect the harness of the MAF sensor in order to verify that it is not routed too close to the following components:
    - The secondary ignition wires or coils
    - Any solenoids
    - Any relays
    - Any motors
    A low minimum air rate through the sensor bore may cause this DTC to set at idle or during deceleration. Inspect for any vacuum leaks downstream of the MAF sensor.
    A wide open throttle (WOT) acceleration from a stop should cause the MAF sensor g/s display on the scan tool to increase rapidly. This increase should be from 6-12 g/s at idle to 230 g/s or more at the time of the 1-2 shift. If the increase is not observed, inspect for a restriction in the induction system or the exhaust system.
    The barometric pressure (BARO) that is used in order to calculate the predicted MAF value is initially based on the MAP sensor at key ON.
    When the engine is running the MAP sensor value is continually updated near WOT. A skewed MAP sensor will cause the calculated MAF value to be inaccurate. The value shown for the MAP sensor display varies with the altitude. With the ignition ON and the engine OFF, 103 kPa is the approximate value near sea level. This value will decrease by approximately 3 kPa for every 305 meters (1,000 feet) of altitude.
    A high resistance on the ground circuit of the MAP sensor can cause this DTC to set.
    Any loss of vacuum to the MAP sensor can cause this DTC to set.
    If you suspect the condition may be related to aftermarket accessories, refer to Checking Aftermarket Accessories in Wiring Systems.
    '99
    Tone, he edited in the code after some of the replies. I asked him what code he was getting in another thread and he posted the code here in this thread.
    http://www.vehicross.info/forums/showthread.php?t=12188
    Mark
  1. Stalling. At wits end!
    By dallas121469 in forum VX Troubleshooting...
    Last Post: 05/07/2017, 06:49 PM
  2. stalling when starting
    By circmand in forum VX Troubleshooting...
    Last Post: 01/30/2014, 04:48 PM
  3. stalling problem...............
    By H3_VX in forum VX Troubleshooting...
    Last Post: 06/19/2013, 05:03 PM
  4. smell and stalling
    By 99VX4x4 in forum VX Talk...
    Last Post: 10/06/2005, 08:44 PM
  5. stalling problem
    By Joe C in forum VX Troubleshooting...
    Last Post: 01/29/2003, 03:27 PM
