Results 1 to 3 of 3
Thread: Belt Tension Bolt - Where???
    Feb 2003
    1999, kaiser silver, VX
    Can someone explain exactly where the belt tension bolt is? I know from reading another thread that it's 14mm, but I wasn't sure which pulley the bolt is located since I found 2 14mm bolts. Never did this before, but I'm trying to replace my alternator. Thanks.
    '01 Ebony #0939
    Are you just trying to release the tension on the drive/serpentine belt? If so, the nut you'd want to put the 14mm wrench on is on the automatic belt tensioner pulley. That pulley is located just above and between the generator pulley and the crankshaft pulley.
    Once you have the wrench (or socket w/ratchet) on that nut, lever it clockwise to release the tension on the belt.
    Lightbulb
  1. 3.2L V6... same bolt pattern as 3.5?
    By SilverBullet75 in forum VX Talk...
    Last Post: 12/15/2011, 07:11 AM
  2. Front Seat Belt Torx Bolt
    By darkl4805 in forum VX Troubleshooting...
    Last Post: 12/10/2006, 04:51 PM
  3. Bolt size
    Last Post: 09/12/2006, 10:56 PM
  4. WMS - WMS VX 12 bolt?
    Last Post: 01/31/2006, 06:12 PM
  5. wheres the rear seat belt bolt go?
    By -x- in forum VX Troubleshooting...
    Last Post: 06/02/2003, 12:29 PM
