After 83k my stock exhaust has finally given up on me, I can easily put a screwdriver through it...
The front pipes still seem good so I am going to replace the muffler, tailpipe, and add a resonator tip.
I've decided on a MagnaFlow muffler that was the closest to stock size. (this one is actually 2 inches longer with a center outlet) I believe it will fit, lots of room between the rear shock and axle. I hope.
Then I'm going to have the muffler shop, who says they do custom mandrel bent pipes, fab up a tail pipe with a Monza big-bore pencil tip.
This size muffler is only available with 2.5 in/out lets, I figure they can adapt it to the stock 2.25 front pipe. I ordered the Monza tip w/2.5 inlet also, so the tailpipe is increasing a bit.
Your thoughts?... Discuss.
