Results 1 to 15 of 15
Thread: Diff Drop Brackets
Threaded View
ZEUS Diff Drop Brackets 10/09/2007, 08:31 PM
tom4bren Good stuff. Thanks Zeus. 10/10/2007, 04:04 AM
CrnCnn So, uh, you wanna make me a... 10/10/2007, 05:23 AM
ZEUS Clint, I'm sure Beau would... 10/10/2007, 06:45 AM
tom4bren Yeah, and I was thinking... 10/10/2007, 10:14 AM
    Diff Drop Brackets
    Here is what I did to drop my front diff to alleviate the sharp CV angles after a lift:
    I cut out the lower portion of each bracket by making two 90* straight cuts on each. I then cut off two 2" wide strips from a Jeep bumper I had laying around. The bend at the bottom of the bumper matched the roll in the stock brackets. I hammered on the strips a little to perfect the shape and to fill the hole I made in the stock brackets. Then I welded the strips to the lower part of the bracket. Here is what I got:
    Attachment 561Attachment 562
    After welding the 2"-extended lower portion of the brackets to the upper portion, I had to grind the welds down on the backside of the brackets in certain spots to allow a tight fit against the axle housing. I was also able to mark the two additional holes needed for the mounting bolts to go through. After a test fit, I painted everything up:
    Attachment 563Attachment 564Attachment 565
    I have seen another approach where a C-shape was cut out of the brackets to achieve nearly the same result. A piece of plate must have been used, and then all five holes were drilled into it. This was BigMeatVX's approach:
    [IMG][/IMG]
    I think mine were easier to create, but BigMeatVX's might have more strength. However, I don't think mine will fail either. I will post my solution to the crossmember drop after I figure it out!
  1. My Diff Drop Brackets!
    Last Post: 06/08/2018, 06:42 PM
  2. Diff Drop Axle Brackets
    By Joe Darlington in forum VX Modifications...
    Last Post: 05/03/2013, 07:57 PM
  3. Diff Drop Brackets
    By UWVX89 in forum VX Modifications...
    Last Post: 11/18/2012, 12:06 PM
  4. Diff Drop Brackets
    Last Post: 04/04/2011, 06:40 AM
  5. Differential drop brackets
    By Ascinder in forum VX Modifications...
    Last Post: 03/24/2007, 04:52 PM
