Wow glad this site is back up so I can talk to the smart guys.......
Okay
TOD gauge shows no green led's in the front wheels and all the green leds are lighted on the rear wheels all the time. This is not the way it used to be..maybe a 1/4 of the led's on take off from a light. I couild get them all to work if I stomped on it from a stoplight.
There is a "red" led check lite that starts flashing after driving about a 1/4 mile every time the engine is started. All this shows up in the normal mode. All the green led's light up in compound low on the dirt I haven't messed with locking it up in compund low on pavement.
But in the "normal" mode the wheels start "wrapping up" when I try to turn the wheels such as into a parking space. They will , "bind up" then release with a popping feeling, then bind up again. Kinda like that that feeling when you go off road with other cars and you have locking hubs and then you forget to unlock the hubs and go onto the pavement and make a sharp left or right and it starts binding up when you go around corners, (inside wheel going slower then the outside wheel...somethin is not right folks HELP![]()
JDM Vx's. We have H2 - TOD - L4 all from standard.
