Originally Posted by
IndianaVX
are you replacing the whole window just because of the clips????? i would replace just the clips if thats the case, or get ahold of dino, i think, with his solution.
there are also clips at gm dealerships that worked, i think 3 bucks a piece, the search should bring that up.
anyway, just thought it was alot of trouble, and money, for a clip fix....
someone here, can't remember who even though I bought some from him is manufacturing a better clip that has some adjustment to it. Also, if you look at my thread; http://www.vehicross.info/modules.ph...warticle&id=22 there are a few photo's on the door panel removal. good luck
