I've been having a load of problems after installing the Xenon Headlights (from Tone). After initial installation they worked for a few weeks to a month perfectly. Then one day the passenger side stopped working. The headlights are SOOO good that I never noticed driving with only 1 headlight until someone told me. For about a week the headlight would come on then go off (staying on or off for 1 day at a time, it was not like the lights were flashing or turning on and off by hitting bumps).
I contacted Tone and he rushed me a new replacement kit (thanks man!). I installed the new kit and yet again the same side did not work. I checked the fuses including the 10A in the car and the wiring harness, no probs. I troubleshooted each and ever single part of the kit and found the faulty part to be a ballast. I contacted Tone again and he came to my rescue again by swapping out the faulty ballast with a new one. It arrived and I installed it late lastnight. It still does not work. ARGGGGGHHHH
If I take the GOOD ballast and move it to the passenger side of the truck, it works fine. In fact, I drove around for 1 night with it installed like this (with no front bumper). No problem. I put it back on the driver side and it works no problem. I take the BAD ballast (the one I just received) and it won't work on either side.
So the thing is that I've had one good working ballast this whole time. It works on either side of the truck. The system IS installed correctly and professionaly. I have yet again troubleshooted EACH AND EVERY PART going from driver side to passenger side. EVERYTHING works except for this new ballast that I just received. This is the 3rd ballast to go bad (1st from the original kit, 2nd the replacement from the new kit, 3rd from the ballast only replacement I just received).
Please could someone brainstorm with me and give me your thoughts... I just don't have any idea of what is wrong except for the ballast however I understand completely that Tone has an exceptional reputation for sending only quality parts....so I'm at a loss for words...
ANY AND ALL HELP would be greatly appreciated.
Thanks
Tyler
